Running 35's
Old Oct 10, 2007 | 07:04 PM
memphisii's Avatar
memphisii
Default Running 35's
has any one had any sort of rubing problem rubbing with a leveling kit running 35 inch tires and being loaded down prtty good, just want to make sure i dont need to lift the rear also when i do it. thanks
Old Oct 10, 2007 | 08:38 PM
NCcummins's Avatar
NCcummins
Default RE: Running 35's
i dont know about the 06..but with ym 02 and a triple axle trailer and 2 or 3 rock krawlers...never rubbed the tire....
BTW...buddy has a 08 superduty witha 6 inch lift and 22 inch wheels and 40 inch tires coming out in next diesel power...rubs over every bump ;-).......shoulda built a MEGA CAB instead!
Old Oct 10, 2007 | 11:06 PM
1tonmegacab's Avatar
1tonmegacab
you will have no worries on the rear and unless u get the proper wheel back spacing you will rub on the front even with a 3 inch spacer
and pretty much any spacer bigger than a inch to a inch and a half you will needs blocks or something in the rear to make it level again as the front will be higher than the rear
i had 35s with a3 inch kiton my 06 mega cab the wheelswere 18s with 4.5 back spacing and they rubbed ( never on everyday reg road driving)the inner fender when i drove off the road into a dip like a small ditch or something
in order to make a 35 fit proper with no rubbing issues you will need a backspacing as close to stock wheel as possible ( i think its like 5.5-6)
hope that helps some
Old Oct 10, 2007 | 11:24 PM
tonyslaramie's Avatar
tonyslaramie
I run the 35's on stock wheels, no rubbing, however I'm concerned about snow-chains.
Old Oct 11, 2007 | 09:17 AM
NCcummins's Avatar
NCcummins
thats crazy they rubbed! never thought they would!
