makin an up grades list for my 1st gen...
Old Oct 16, 2007 | 11:03 AM
CutterW's Avatar
CutterW
Default RE: makin an up grades list for my 1st gen...
12V+Screwdriver=Horsepower?
Old Oct 16, 2007 | 05:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Drew
if your gunna do an e-brake you will need to get some 60# valve springs or you'll float a valve when the thing kicks on.
so Ill have to remove the head from the engine. that old of a p[ower plant, I would hate to remove it and cause new issues..
Old Oct 16, 2007 | 05:01 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: lilfroger
hmmm a new driver maybe?
O! you funny girl!!!
Old Oct 16, 2007 | 05:14 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: lilfroger
She got you. She must have seen you drive.
Old Oct 16, 2007 | 05:18 PM
Drew's Avatar
Drew
ORIGINAL: Kev_n_AZ
ORIGINAL: Drew
hate to say it but yea, off with the head, thats the only way your gunna get the spring keepers out without the valves finding their way into the cylinder. this would also be a good time to slap on a new HG
Old Oct 16, 2007 | 06:02 PM
jakebrake's Avatar
jakebrake
Actually you can replace them without pulling the head. What you do is rotate the engine so that the cylinder your workin on is a tdc. This will keep the valve from falling out of the head. They make a special spring compressor to remove the spring without pullin the head. I believe napa or autzone sells them.
Old Oct 16, 2007 | 06:27 PM
Jr. Mechanic's Avatar
Jr. Mechanic
I know, before anything else, maybe you should fix that loose nut behind the wheel
Old Oct 16, 2007 | 10:20 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Jr. Mechanic
is that you followin me around town??
Old Oct 16, 2007 | 10:37 PM
Kev_n_AZ's Avatar
Kev_n_AZ
heres what I have learned so far:
to upgrade exhaust from 3" to 4" stright pipe,I have to change turbos. mine lacks the bolt on plate. the exhaust just uses a band to attach to the turbo housing.
my turbo has NO waste gate.
an intake elbow would help greatly!!
add a second battery
exhaust brake requires torque convertor control unit.
Old Oct 17, 2007 | 10:49 AM
Drew's Avatar
Drew
you can still go to a 4". . .I believe there is a manufacturer that makes the pipe that necks down to 3.5" for the turbo.
