Help with DIY ujoint lube
Old Oct 24, 2007 | 05:57 PM
Erock509's Avatar
Erock509
Default Help with DIY ujoint lube
So i was looking through the DIY section and figured it would be a good idea to lube the u joint and any other locations. im a little confused about what to use to get this done. If someone could please tell me exactly what i need parts wise, to get the job done. i have nothing, so i guess ill need it all. thnx
Old Oct 24, 2007 | 09:44 PM
jakebrake's Avatar
jakebrake
Default RE: Help with DIY ujoint lube
I believe the napa part number for the grease gun tip is 715-1200. And of course youll need a grease gun with grease.
Here's a pick of the tip needed for referance
Old Oct 24, 2007 | 09:59 PM
Erock509's Avatar
Erock509
Ok, can also recommend what grease gun and grease. plus will this fitting work for all the points that need lube?
Old Oct 24, 2007 | 10:21 PM
jakebrake's Avatar
jakebrake
I prefer this type of gun
You'll want one with the hose attatchment (makes life so easier) and then Try to get synthetic grease if you can. If you can't this will work just as well.
Old Oct 24, 2007 | 10:24 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: jakebrake
Why do you prefer that over a air powered grease gun?
