01 ram with 5.9
Old Oct 25, 2007 | 05:07 AM
captjim1's Avatar
captjim1
Default 01 ram with 5.9
Father has a 01 with the 5.9 diesel. With the new low sulfur fuel should he be adding some lubricant to the fuel? Has cummins recommended this? He says his engine sounds different but has gotten better fuel milage. He has about 80,000 miles on it.
Old Oct 25, 2007 | 06:36 AM
Super Dave's Avatar
Super Dave
Default RE: 01 ram with 5.9
Does it NEED more lubricant--no, will it hurt to add lubricant--no. Most people do notice a reduction in noise when using a lubricant additive, so I think it helps. I personally use the Power Service because I think it helps keep the injectors clean and in turn helping the mileage. It also quiets ths rattle down a bit, and I don't see how that could be bad.
Old Oct 25, 2007 | 08:00 AM
CowboyBob's Avatar
CowboyBob
Run B20 and all of your problems will be solved.
Old Oct 25, 2007 | 09:16 AM
NCcummins's Avatar
NCcummins
i use lucas and like it alot!
Old Oct 25, 2007 | 12:44 PM
Mayfair's Avatar
Mayfair
I'm running 1oz of Walmart 2-stroke oil per gallon of fuel. Quiets it right down and helps to protect / lube that costly VP-44.
