What does REMOVING intake baffling do?
Old Oct 25, 2007 | 10:48 PM
sallyman1's Avatar
sallyman1
Default What does REMOVING intake baffling do?
i heard lots say it gives more turbo noise but does it help or does it reduce airflow? Does it make things worse or not? I know on the big diesel trucks there is nothing in their piping(elbows, str8s, etc..)Just a huge air filter enclosed.Why did dodge/cummins throw baffling and air deflectors in our intake piping there must be a reason?
Who has removed baffling and deflectors in elbow? and have you seen MPG increase?
Also wondering what that thing is in my str8 piece from elbow up to filter? feels like theres a cross shaped thing in there can i gut it all?
Old Oct 26, 2007 | 07:49 AM
sallyman1's Avatar
sallyman1
Default RE: What does REMOVING intake baffling do?
any1? am i the first to do this
Old Oct 26, 2007 | 08:04 AM
UpBranchLiner's Avatar
UpBranchLiner
Just makes a louder whirling noise, might as well pull the silencer ring while your doing that. No difference other then noise increase
Old Oct 26, 2007 | 08:36 AM
bert0168's Avatar
bert0168
Your not alone. I took out the white fins in the lower elbow and used a dremel to remove the guts out of the hard black plastic tube in the middle. No difference in performance but BIG difference in turbo noise. I am running stock muffler for now and wanted to increase the turbo whine but keep a stock look to the tubing.
Old Oct 26, 2007 | 02:03 PM
Mayfair's Avatar
Mayfair
I don't have the same year Ram as you so I don't knwo the answer, however I believe it's mentioned in the silencer ring removal thread that it tacked up top in the DIY section.
Old Oct 26, 2007 | 02:08 PM
aka_chewy's Avatar
aka_chewy
Removing it does nothing other than your able to hear the turbo sing a little more.I took mine out 6,000 miles ago and I haven't noticed any change, other than turbo whistle. I didn't notice the turbo spool any faster.
Just sounds awesome.....
Old Oct 27, 2007 | 12:14 AM
sallyman1's Avatar
sallyman1
thanks guys. ill check DIY section
