Exhaust Manifolds?
Old Oct 26, 2007 | 06:01 PM
R0oster31's Avatar
R0oster31
Default Exhaust Manifolds?
I am looking for a little quicker spool up and supposedly exhaust manifolds can make a difference. I was just wondering what you guys thought and also which ones are good.
http://www.scheiddiesel.com/Ex_manifold.htm
http://www.genosgarage.com/prodinfo....ber=BD-1045985
http://www.puredieselpower.com/catal...old-p-457.html
Pure diesel power's is the cheapest and comes with all the mounting hardware but then again there is also the ATS and the BD. From the exterior they all look the same, I was wondering which ones are better. If anyone has heard good bad or otherwise about any of them or if I am missing one I am just trying to do a little research.
Old Oct 26, 2007 | 07:18 PM
triton's Avatar
triton
Default RE: Exhaust Manifolds?
I think you could spend your money better on something else. If anything, one of the manifolds are going to make it spool worse. They're flow more freely and are larger so, that's not gonna help. I'm surprised you're having a problem spool a 62. What size is the exhaust side? A tighter torque converter might help you to get what you're looking for.
Old Nov 4, 2007 | 11:02 PM
R0oster31's Avatar
R0oster31
The truck doesn't have a problem spooling the turbo, I would just like it to spool a little quicker. The exhaust side is a 73mm turbine in a 14 cm housing, as far as a torque converter I must have missed that when I was putting in the dual disc...
