Red fluid leak
Old Oct 28, 2007 | 07:35 PM
RamQuadHD's Avatar
RamQuadHD
Default Red fluid leak
Hey people, does any one know what a red fluid leaking from underneath culd be? It is more towards the passenger side. I put a clear cup to catch it and the fluid is really red(not brownish at all).
EDIT.............................................. .................................................. .................................................. ........
Took it to dealer and they said it was just coolant leaking from a loose clamped hose from underneath the turbo. I guess I could've checked that myself but it was too dark out. Anyways, I guess I just got a $60 truck wash. Thanx for all your inputs.
Old Oct 28, 2007 | 07:37 PM
FroneDaddy's Avatar
FroneDaddy
Default RE: Red fluid leak
Check the transfer case, it uses tranny fluid. Or it could be tranny fluid from the tranny.
Old Oct 28, 2007 | 07:48 PM
hocheck's Avatar
hocheck
If it is coming from the passenger side it is probally blinker fluid.
Old Oct 28, 2007 | 11:15 PM
mileshuff's Avatar
mileshuff
ORIGINAL: hocheck
Is that the same stuff as muffler bearing lube?
Old Oct 28, 2007 | 11:28 PM
Parts/Service's Avatar
Parts/Service
trans or transfer case fluid.........
Old Oct 29, 2007 | 06:10 AM
sabersix's Avatar
sabersix
ORIGINAL: RamQuadHD
Did you check the ground clearance under your truck? You might be draggin something... [8D]
[IMG]local://upfiles/52139/178FF97D8EFC4CBCA2E2A63A5B29B8B6.jpg[/IMG]
Old Oct 29, 2007 | 08:19 AM
RamQuadHD's Avatar
RamQuadHD
No, my truck is not really lowered, that is just a photo-chop. I guess I will make a trip to the dealer today. Thanx for all your inputs.
