YAHOO injectors are heres
Old Oct 29, 2007 | 06:45 PM
woligator's Avatar
woligator
Default YAHOO injectors are heres
My stage 3(100hp) nozzles are here,tomorrow ill prolly install them whit my new BD fuel pump,
so i wont have to bled the system 2 times....
im kinda happy
Old Oct 29, 2007 | 06:52 PM
jakebrake's Avatar
jakebrake
Default RE: YAHOO injectors are heres
While you got yur valve cover off, you might aswell do a valve adjustment too.
Injector install link
http://consortiumlibrary.org/staff/t...structions.pdf
Old Oct 29, 2007 | 08:34 PM
woligator's Avatar
woligator
Valve adjustment ???
can u be more clear plz jake?
I readed the DIY section on this,thx jake
Old Oct 29, 2007 | 11:29 PM
solarwarp's Avatar
solarwarp
SMOKE! SMOKE! SMOKE!
We want to see the Woli-beast smoke.
Old Oct 30, 2007 | 12:09 AM
squirtbottle09's Avatar
squirtbottle09
I didnt know yahoo made injectors. Lol, just messing with ya man.
Old Oct 30, 2007 | 12:30 AM
jakebrake's Avatar
jakebrake
No problems, the one thing different between the vp44 engine and the cr engine on the valve adjust is the timing mark is behind the breather element. Pull the tube off, use a ratchet handle or something to stick into the element outlet and twist it off (counterclockwise). You'll need a mirror to get a good look at the timing mark, line the mark up, then with a paint pen or something mark the balancer to the front cover. Then adjust the first set of valves. Then rotate the engine over one turn lining the marks up you made on the balancer and front cover and adjust the second set of valves.
Old Oct 30, 2007 | 06:38 AM
woligator's Avatar
woligator
Solar,u will see it,i cant wait to darken the sky
Old Oct 30, 2007 | 08:25 AM
NCcummins's Avatar
NCcummins
let us know how it goes!
Old Oct 30, 2007 | 08:36 PM
woligator's Avatar
woligator
Welll i didnt finish tonight,if i had ill miss my girly before she go to sleep so i had to stop at 6:30
i have started this at 3...
ive installed my new BD lift pump kit,switched all the injectors nozzle,only the cover and the heatgrill,intake to go and the camshaft position sensor...
ive broken a bolt on a injector hold on plate...u know that feeling...
a bit more torque and thats it,CLACK HO ****.....
so i have to get one now...ill get a grade 8 bolt tomorrow...9.6 rating on the bolt...
this is very easy save for the last one near the firewall...i u got big arm like mine its very difficult to get the line off....
Old Oct 30, 2007 | 09:10 PM
solarwarp's Avatar
solarwarp
Oh, that's cool... the sound of a bolt breaking off makes the same sound in French as is does in English. [:@]
