not starting as good
Old Nov 6, 2007 | 09:53 AM
shampoo's Avatar
shampoo
Default not starting as good
when i crank the truck, it seems to take longer than before. would this be the lift pump going bad?
Old Nov 6, 2007 | 10:18 AM
Drew's Avatar
Drew
Default RE: not starting as good
possably. . .also check the condition of the batteries.
Old Nov 6, 2007 | 10:21 AM
shampoo's Avatar
shampoo
thanks drew. the batteries are fine. the motor turns over fine. its like it is waiting on the fuel to get too the injectors
Old Nov 6, 2007 | 11:09 AM
Drew's Avatar
Drew
it would be a good idea to hook a pressure gage up to the inlet to the CP3 and see what the pressure is. . .at idle anything below 10-12psi and you would need to look into getting it replaced.
Old Nov 6, 2007 | 05:13 PM
shampoo's Avatar
shampoo
would it hurt anything running it at low pressure.
Old Nov 6, 2007 | 09:29 PM
sallyman1's Avatar
sallyman1
does it hurt running it at low pressure other than your pump failing whenever? also on the cp3 there is a port to plug into isnt there? Does any1 know the port or fitting we need to tap into? I have gauges at home but my couplers are different
