2006 front unit bearings
Old Nov 23, 2007 | 01:04 PM
rootercycles's Avatar
rootercycles
Default 2006 front unit bearings
how do I get the front unit bearings off of the spindles? I have removed the rotor, caliper and outer retaining nut. Will I need a puller? I want to retain the integrity of the unit bearing if I can. I am going to NAPA to get a 4 arm puller now. If I pull the hub and bearing straight off, will the bearing come with the outer hub? I am starting an EMS free spin kit but the directions I have are less than stellar.
Old Nov 23, 2007 | 01:08 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: 2006 front unit bearings
ORIGINAL: rootercycles
Take pics throughout and do a diy.... there is a bearing repack diy in there.
Old Nov 23, 2007 | 01:48 PM
Splicer's Avatar
Splicer
Check some write ups on this before you go pulling on that bearing. I believe there are some more bolts holding that thing on from behind the assembly.[sm=confused06.gif]
