Cant keep truck in overdrive pulling? 2004.5 ram
Old Nov 24, 2007 | 01:19 PM
sallyman1's Avatar
sallyman1
Default Cant keep truck in overdrive pulling? 2004.5 ram
I have a ram 2500 diesel 5.9 cummins 2004.5 quad cab 4X4. I brought my new camper (2008 cougar 304bhs 34 foot 7600 lbs dry) home the other day. iwent through hilly terrain and couldnt keep overdrive on(which i expected i guess) I had to push the towhaul button and go about 90 km hour. it revs higher because its locked in 3rd but whatever. my ? is the trailer was dry empty and not even loaded. Will a edge juice attitude, with a and e filter intake and CATYLIC CONVERTER REMOVAl help me pull this unit? will it allow me to stay in overdrive or not?
Old Nov 24, 2007 | 01:33 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: Cant keep truck in overdrive pulling? 2004.5 ram
It should. However you might be better off in tow haul mode as it will put less stress on transmission with keeping the right gear for the right amount of time. they have programmers with specifis for towing. My predator has a tow mode. I know s/c does.
Old Nov 24, 2007 | 01:40 PM
sallyman1's Avatar
sallyman1
what name brand is predator and what is s/c? does an edge, or bullydog adjust tranny parameters as well?
Old Nov 24, 2007 | 01:45 PM
JimmyDiablo
ORIGINAL: sallyman1
diablosport.
Old Nov 24, 2007 | 01:47 PM
JimmyDiablo
http://www.diablosport.com/index.php...lay&pid=72
Same one I have. this thing is great for the price and you can find a good deal on aused one I am sure. plus you can stack with power puck down the road if you so desire. only down fall no built in guages.
Old Nov 24, 2007 | 03:24 PM
sallyman1's Avatar
sallyman1
what other units specifically apply to towiing? are there any bad ones.? I heard bullydog systems can wreck truck or that they dont have protective measures built in like edge?is this true?
Would removing just CAT be my best bet? or leave cat and delete muffler only?
