rims
Old Nov 29, 2007 | 11:41 PM
tdmopar59's Avatar
tdmopar59
Default rims
http://store.summitracing.com/partdetail.asp?autofilter=1∂=CRR%2D3978980&N =700+4294923107+4294923105+4294793320+4294795022+4 294755950+115&autoview=sku
how will these do with a 2" leveling kit and 35's....? is everything else alrite too???
im about to order be quick!! THANKS!!!
Old Nov 29, 2007 | 11:48 PM
energinerbuzzy's Avatar
energinerbuzzy
Default RE: rims
With a leveling kit it might work. But they will stick out almost 3/4 inch further than the wheels on my truck. If they do rub it might just be by a little bit.
If the information about the offset is correct, they will stick out 2.25" further than your stock rim. And if you put a wider tire on there, then the tire will stick out even further.
Things to consider before you but them!
Old Nov 29, 2007 | 11:51 PM
energinerbuzzy
Default RE: rims
DELETE, I'm a dumb ***
Old Nov 29, 2007 | 11:52 PM
tdmopar59's Avatar
tdmopar59
Default RE: rims
wat specs do you reccomend....? i could always do fender flares...
Old Nov 29, 2007 | 11:56 PM
KillerCummins's Avatar
KillerCummins
Default RE: rims
With that Hemi, say adios to your 13mpg. Just make sure you can afford a decrease in your fuel economy. I would of thought mine over. Just sharing my experience.
Old Nov 29, 2007 | 11:58 PM
energinerbuzzy
Default RE: rims
DELETe
Old Nov 29, 2007 | 11:59 PM
tdmopar59's Avatar
tdmopar59
Default RE: rims
i have a 2500..... so please continue with the info!!! gas mileage... its gone anyway....
Old Nov 30, 2007 | 12:01 AM
energinerbuzzy
Default RE: rims
OMG I need glasses, I thought I saw 6 lug. Read my first post, those specs do apply to your truck. And the only thing I can recomend is what I know for sure works and that is a +18 offset with 5.71" backspaceing.
Old Nov 30, 2007 | 12:05 AM
tdmopar59's Avatar
tdmopar59
Default RE: rims
well im gonna try these cragars.... they look bad @$$ and are a great price.... hopefully not too much rubbing... 8x6.5 on bolt pattern? THANKS for the help buzzy
Old Nov 30, 2007 | 12:29 AM
Mayfair's Avatar
Mayfair
Default RE: rims
Dude they are BADD AZZ !!!!
Will they work on my Ram?
