Lose RPM guage and engine has less power
Old Dec 5, 2007 | 09:02 AM
stevenh_72's Avatar
stevenh_72
Default Lose RPM guage and engine has less power
While driving my 01 Ram Cummins diesel down the road my RPM gauge will intermittently drop to 0 and the truck will start to run a little rough and seem to have less power. All the other gauges will continue to work fine. While continuing to drive the RPM gauge will start to work again and the engine begins to run smooth again and the power seem to be back to normal. The engine light is on so I checked the codes and got PCU-1693 and ECU-341. Any ideas what might be wrong or going bad?
Old Dec 5, 2007 | 09:06 AM
Drew's Avatar
Drew
Default RE: Lose RPM guage and engine has less power
P1693Turbo Charge Control Circuit Malfunction. . . .Id be wondering if your cam sensor is having fits and also check your MAP sensor and clean it if necessary.
Old Dec 5, 2007 | 08:35 PM
woligator's Avatar
woligator
mine 01 did exactly the same
but my codes werent the same tough
it was the CAM SENSOR
this is a pain to change if ur strongly build...but after its so sweet
Old Dec 5, 2007 | 09:06 PM
roadking096's Avatar
roadking096
Doesn't the crank position sensor cause the same symptoms? thought I read that here before.
Old Dec 6, 2007 | 06:35 AM
woligator's Avatar
woligator
dunno roadking,i know if cam sensor is gone tach is gone but crank speed is used to somewhere for sure
