HVAC Question...
Old Dec 5, 2007 | 11:32 AM
seattlestones's Avatar
seattlestones
Default HVAC Question...
So I was driving in this morning with the heater on. I noticed it was getting cooler in the truck. I turned up the fan speed a little with no discernable heat coming from any of the vents. I tried switching the direction of the vents, but nothing was coming out. The fan works, but something seems like it is blocking the inlet to the fan. Any ideas? Could this be as simple as a burnt fuse? I really don't wan't to take it in for warranty work for something simple. As always, I appreciate your help!
Old Dec 5, 2007 | 12:09 PM
tdmopar59's Avatar
tdmopar59
Default RE: HVAC Question...
HVAC in my opinion is always a PIA because its normally a PIA to get to... if you are under warranty and you are covered.. let them deal with it!! just my .02
Old Dec 5, 2007 | 12:14 PM
Drew's Avatar
Drew
the blend door is a known culprit of HVAC problems. another problem if you lost heat would be from the **** itself going out, or the mechanism that controlls the flow of engine coolant to the heater core. . .the latter of which is a PITA to get to.
Old Dec 5, 2007 | 12:40 PM
spfd308's Avatar
spfd308
my blender door broke on mine. got it replaced on warranty. take it in let them fix it. haven't had any problems since they replaced the part.
Old Dec 5, 2007 | 12:54 PM
seattlestones
Thanks for the quick response! I appreciate it! I made an appointment w/ the delaership. I am going to try and get it in either today or tomorrow. I will let you all know what comes up. Thanks again!
Old Dec 5, 2007 | 01:00 PM
tdmopar59's Avatar
tdmopar59
Hey no problem thats wat we do! good luck!
Old Dec 5, 2007 | 07:17 PM
R0oster31's Avatar
R0oster31
Let the dealership play with it if they will do it for free, I've had mine apart, you have to drain the coolant, the refrigerant (AC system), and take your dash out.
