my brothers 01 won`t start
Old Dec 7, 2007 | 10:03 AM
Irish4u1978's Avatar
Irish4u1978
Default my brothers 01 won`t start
My brother`s 01 won`t start. It started this morning, he drove a mile and it quit. The fass pump is working, the fuel filter is new, the injector pump is a year old. No codes. Everything else is stock. What could it be? Kevin
Old Dec 7, 2007 | 10:53 AM
Drew's Avatar
Drew
Default RE: my brothers 01 won`t start
have you hooked it up to a computer to see if there are any codes???
Old Dec 7, 2007 | 11:35 AM
Irish4u1978
Just the self check so far. Hes going to pick up a scanner to check it with that.
Old Dec 7, 2007 | 03:29 PM
Drew's Avatar
Drew
when he does that let us know if he finds anything. . .hopefully you dont get the 0216. . .that is the death code for the VP44
Old Dec 7, 2007 | 09:50 PM
jakebrake's Avatar
jakebrake
The key trick should work on it.
Old Dec 7, 2007 | 10:31 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: jakebrake
doesnt that usually cost a bit extra $$ ????
Old Dec 8, 2007 | 12:44 PM
Irish4u1978
Nothing came up on the scanner either. So assuming that everything is ok he loosened the lines on the injector pump and that did it. Turned out air got in it. I think a loose line before the fass pump caused the problem. So he changed both fuel filters and checked/tightened all the connections and all in well. Thanks guys. Kevin
