Weired Vibration
Old Dec 20, 2007 | 12:30 AM
steve05ram360's Avatar
steve05ram360
Default RE: Weired Vibration
Thanks for the suggestions... I think though if it were a ujoint, wouldnt it be vibrating under acceleration load? this vibration I think is more of a shimmy. I know the passenger side tre is loose as is the drag link. I was going to swap the steering out for the thuren setup but I think I need to just swap the parts and get it working right again. If I'm wrong and that doesnt fix it, at least I'm not out the $500 bux to do the thuren swap... it's something like $160~180 IIRC. If that does fix it, then I'll start from there and go get the steering stabilizer for the gear box. This weekend I'll check out the drive shaft up front to see if there is any play. I'll also do as suggested and look at the axle joints.
