fass?
Old Dec 26, 2007 | 04:09 PM
alansimpson04's Avatar
alansimpson04
Default fass?
should i go with the fass fuel system or just the fass fuel pump?
Old Dec 26, 2007 | 04:18 PM
Drew's Avatar
Drew
Default RE: fass?
if you are going to go, go all out. you will get better filtration with the fass filters.
also consider the walbro pump setup from glacier diesel performance
Old Dec 26, 2007 | 04:22 PM
alansimpson04
Default RE: fass?
which one would yall recomend then?
Old Dec 26, 2007 | 08:40 PM
jakebrake's Avatar
jakebrake
Default RE: fass?
I got the fass 95gph pump with the 150 (larger) filters.
Old Dec 28, 2007 | 02:06 PM
02cummins's Avatar
02cummins
Default RE: fass?
fass system because i priced out the same thing, pump alone is over 400$, 200 more and u got the heater/filters etc.
Old Dec 28, 2007 | 03:12 PM
CowboyBob's Avatar
CowboyBob
Default RE: fass?
I've got a Walbro it's cheaper but a little bit harder to install.
Old Dec 28, 2007 | 03:23 PM
woligator's Avatar
woligator
Default RE: fass?
i got a bd pump,not that bad to install
