Oil Additives..?
Old Dec 29, 2007 | 01:35 PM
websterdan's Avatar
websterdan
Default Oil Additives..?
With all this talk about BIO Diesel and Fuel Lube Additives, as anyone thought about just adding straight cooking oil (Canola, Peanut) or anything else. Like a qt every fill up. Since BIO is filtered cooking oil why not just pore in new as a lube????
Old Dec 29, 2007 | 04:21 PM
CowboyBob's Avatar
CowboyBob
Default RE: Oil Additives..?
Ask jimmydiablo, I think he is running straight veggie oil in his truck. I am running b20 and I kow that it works better than D2 with any additives.
Old Dec 29, 2007 | 09:11 PM
HankL's Avatar
HankL
fats (olive oil, old grease, canola oil, etc)
are three long chain 'fuel like' molecules
attached to a glycerin connector
to make these fats more like conventional diesel fuel
you need to react them with alcohol to release the glycerin.
This is the simple step that a 'Bio-Fuel' factory does
to make fat and waste cooking oil into diesel fuel that won't gell quickly
You can burn fat directly,
but most times it needs to be heated with a coil in the tank to work well
http://www.biodieselmagazine.com/art...rticle_id=1755
Old Dec 30, 2007 | 12:54 AM
websterdan's Avatar
websterdan
I understand how BIO is made. I'm talking about just using a qt of veggie oil for fuel pump lube, instead of 2 cycle oil or any of the other snake oils used. According to the LUBE Study on here previously Bio (B20 I believe) had the best anti wear properties of anything. So, I was wondering if anyone had tried it, or it wasn't safe, or anything else...
Thanks for the input so far though.
