How to find boost leak?
Old Jan 5, 2008 | 03:52 PM
Irish4u1978's Avatar
Irish4u1978
Default RE: How to find boost leak?
The reason I think I have a problem is that for the last 75,000 miles with the edge set at stock (boost fooling is always on) My boost has always easily went to 35psi under all speed/driving conditions when I`m heavy on the throttle. With the edge turned up, even to only level one the boost is always 36-38psi when heavy on thottle. Ok, so lets say I don`t have a leak, why all the sudden is it different then is has been? Thanks for everyones input so. Kevin
Old Jan 5, 2008 | 04:17 PM
sallyman1's Avatar
sallyman1
does the edge juice attitude have a boost fooler?
Old Jan 5, 2008 | 04:25 PM
cumminalong's Avatar
cumminalong
ORIGINAL: sallyman1
Not really a boost fooler, but the waste gate is electric so the Juice module just opens it at the pressure you set on the Attitude module.
Without the module, boost fooler, whatever.....you kinda feel a surge in the engine power when you are into the throttle kinda hard. That's the waste gate opening and closing at about 26 psi.
That's one of the things I really like about it.....no more surge. Just a constant push.
