thermostat Bad?
Old Jan 10, 2008 | 04:57 PM
spfd308's Avatar
spfd308
Default thermostat Bad?
so tyesterday it's 37 degrees. i'm driving down the road truck is warm at 200. pull up to a stop light and the temp gauge drops and cold air starts cmoing out of the vents. get a green light take off temp gauge jumps back up and hot air starts blowing again. today it's 50 degrees out and i'm driving down the road coming home. temp guage soars to about 210 degrees and stays. i turn on the heater and it holds at 210 till i get home about a half a mile and shut the truck off. 2 questions. does this sound like a bad thermostat to everyone and would this be covered under the engine warranty. any info appreciated.
Old Jan 10, 2008 | 05:04 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: thermostat Bad?
could be
t stat
or
low coolant level
if not sure, replace the stat and drain all the coolant - replace with new.
last thingsI would wonder is:
clogged heater core
malfunctioning water pump
Old Jan 10, 2008 | 05:34 PM
spfd308's Avatar
spfd308
checked coolant it is good. will have to think aboug the water pump and heater core. it's only a year old so i hadn't thought about those things.
