Modify your own CP3
Old Jan 16, 2008 | 09:34 PM
Drew's Avatar
Drew
Default RE: Modify your own CP3
ty is running dual CP3s
Old Jan 16, 2008 | 10:28 PM
NickBeek's Avatar
NickBeek
The only way I see duals burning up pistons is if you don't add enough air to match all that extra fuel. I think Ty can confirm that one.
Old Jan 17, 2008 | 09:51 PM
dieselram's Avatar
dieselram
Is Ty his screen name here? I'll be running twins and lower compression,trying for 700hp
Old Jan 17, 2008 | 10:01 PM
Drew's Avatar
Drew
Ty = Triton. . .his engine is bored out a bit, mainly to remove the score marks from where he punched a hole through #4 piston. I think he's also running slightly lower compression as well. . .you can put his engine right next to one set up very close and his sounds completely different due to the compression.
