raise or lower?
Old Jan 23, 2008 | 07:57 PM
soniclm's Avatar
soniclm
Default raise or lower?
Well I have a 2001 Extended Cab Short Bed and I am debating rather to lower it down some to level it out or just raise the front. I am gonna fix it up performance wise. I don't really tow anything with it but also don't wanna mess with the leafs and overloads in the back. I haven't been able to find a kit to lower it down in the back because its a 8800 GVW. I would like to what you'll think. Heres a pic of it, it looks like it does in the pic minus a front bumper and a bent it fender. Also I mostly drive on the street if that helps any.
[IMG]local://upfiles/28214/04E229D9E5AF4840A303AEDEACCA3084.jpg[/IMG]
Old Jan 23, 2008 | 08:25 PM
flashpoint's Avatar
flashpoint
Default RE: raise or lower?
RAISE IT!
Old Jan 23, 2008 | 08:30 PM
soniclm's Avatar
soniclm
I thought bout 2 inch leveling spacers in the front then maybe those lefts to stiften the rear end which also liftes it up two inches.
Old Jan 23, 2008 | 09:10 PM
amock's Avatar
amock
Lift it, lowering it is for sissies.
Old Jan 23, 2008 | 09:18 PM
gdwrnch33's Avatar
gdwrnch33
Member
LIFT IT. I HAVE THE 2" LEVELING KIT IN THE FRONT OF MINE, I REALLY LIKE IT.
Old Jan 23, 2008 | 09:22 PM
lilfroger's Avatar
lilfroger
From what I've read you are going to have a hard time finding a kit to lower the back of the truck.
Best thing to do is a 2 or 2 1/2 inch leveling kit. Will give you plenty of room to clear 35's & gets rid of the nose down look.
Old Jan 24, 2008 | 01:17 AM
Mayfair's Avatar
Mayfair
Yeah, I'd level it out.
What kinda rims are those?
Old Jan 24, 2008 | 07:29 AM
soniclm's Avatar
soniclm
IDK off hand but the are from discount tire and they are 17x8.5
Old Jan 24, 2008 | 11:45 AM
92oilburner's Avatar
92oilburner
Is this truck a 4X4? (the front sits kinda low). If it is, a 2' front leveling kit should work out well.
If it is 2wd, you could lower the rear by mounting the springs under the axle.
Old Jan 24, 2008 | 05:34 PM
soniclm's Avatar
soniclm
Well is got alot of spring plus the overloads on the back, pry gonna end up lifting it.
