Need help with Gear Vendor Install
Old Jan 26, 2008 | 09:45 PM
supermototourer's Avatar
supermototourer
New Member
Default Need help with Gear Vendor Install
I am installing a gear vendor unit that I purchased used. A lot of the wires had been cut. I figured most of them out, but I cannot figure out the black labeled wire that goes to the rocker switch. The wire has 6 wires that are combined into three. The rocker switch only has three wires. The wires are combined as follows:
Black and Yellow
Red and Green
Blue and White
Can someone look at their setup and let me know what this wire harness looks like and how it is wired into the rocker switch? Any help would be appreciated. I am trying to attach a picture of the wire in question. I would also like to know if the black wire that comes away from the connector goes to the ground wire.
[IMG]local://upfiles/78782/044F3F2AD1394EB181E51E863ECCC812.jpg[/IMG]
Old Jan 27, 2008 | 08:19 PM
supermototourer
New Member
Default RE: Need help with Gear Vendor Install
Is there anyone that can help with this?
Old Jan 27, 2008 | 09:23 PM
woligator's Avatar
woligator
i have absolutely no knowledge about this,i was sure it was all mechanical no electrical at all sorry
Old Jan 27, 2008 | 09:35 PM
Drew's Avatar
Drew
Ive been thinking about this and looking around. I cant find anything on the electrical install. have you tried posting this question over at Cummins Forum. I know alot of the guy's there have the Gear Vendors trannies installed and can hook you up.
if not, I would call GV up and ask them.
