fixed OD on my 93 ctd
Old Jan 28, 2008 | 09:59 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default fixed OD on my 93 ctd
my over drive went away2 weeks a go. last week it started to work intermittently afterI cleaned the TPS.
ended up disconnecting the TPS and installing a potentiometer* in the dash panel .
this allows you to dial in when your OD engages. anywhere from 35mph to 60mph.
your OD button still turns OD off .
this is very helpful when towing too
I will post pics shortly.!!
this will work in 1st gen ctd's. I undestand that 2nd gen and 3rd gen ctd's are "drive by wire" per se` and this adaption may not work.
* supplies total $20 or less. if you have the soldering iron, solder, and heat shrink...
(new TPS $200+ retail)
potentiometer..$2.99 at radio shack
pin set for TPS connector ...$1.99 at radio shack
heat shrink....$4.00 at harbor frieght
solder iorn...(if needed) $20 most places ...usu has solder in kit.
multi conductor cable..24AWG minimum ...various prices...avail at home depot, radio shack, etc..or use any of these stranded cables: cat5 patch cable, 3-wire power cord up to 16AWG copper (old extension cords.etc), hvy guage speaker cable, or any other stranded 3-conductor cable minimum 24awg..
Old Jan 28, 2008 | 10:59 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: fixed OD on my 93 ctd
here are the pics of the install..before final heat shrink or dash mount...
this pic is of the TPS connector top clip up..with new cable conductors numbered for easy reference...
#1 green
#2 black
#3 white
T - TPS stock connector...no changes to it..
pic is of linear 5k ohm potentiometer in dash..not mounted..
wires identified for easy reference to previous pic...
#1 green
#2 black
#3 white
[align=right]
[/align]
Old Jan 28, 2008 | 01:05 PM
Mayfair's Avatar
Mayfair
Your engine bay is still dirty ...
Old Jan 28, 2008 | 03:22 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Mayfair
why thank you for noticing Mayfair!!!
guess I ned to schedule a DF truck wash day with some scantily clad young ladies
Old Jan 28, 2008 | 03:27 PM
lilfroger's Avatar
lilfroger
ORIGINAL: Kev_n_AZ
and exactly where are you gonna find these ladies?? I don't think a JPG from www.lost.blah blah blah is gonna do you much good in the driveway
Old Jan 28, 2008 | 03:29 PM
Kev_n_AZ's Avatar
Kev_n_AZ
you dont worry your skin toxins away now frogy girl
I have my people !!!
