View Poll Results: A poll
1" leveling kit
0
0%
1 1/2" leveling kit
3.03%
2" leveling kit
75.76%
Don't bother to level at all
12.12%
Just lurking
9.09%
Voters: 33. You may not vote on this poll
Correct leveling kit poll
Old Feb 1, 2008 | 03:11 PM
  #21
cujo's Avatar
cujo
Default RE: Correct leveling kit poll
The only way you are going to always run level is to do a lift kit to be level empty, then do something like add airbags for when you tow the camper to keep from squatting in the rear.
Old Feb 1, 2008 | 03:42 PM
  #22
aka_chewy's Avatar
aka_chewy
Not to fill you head with any more ideas, but you could do the leveling kit, but put a 2" block under the springs. My sister-in-laws husband did that with his and it looks great. Still has the factory stance, but added just enought to make it unique. He's running 35's and it looks really good. And it doesn't look like it's squating
Old Feb 1, 2008 | 04:10 PM
  #23
Mayfair's Avatar
Mayfair
ORIGINAL: aka_chewy
I don't understand what you mean? Isn't what I'm looking at basically the same thing?
Old Feb 1, 2008 | 04:24 PM
  #24
aka_chewy's Avatar
aka_chewy
Sorry...i just re-read that. The level kit goes up front, so now your level. Then, to get the factory rake look back, put 2" blocks under the rear leaf springs. The block goes between your axle and leaf springs. This will give your truck a 2" lift all around.
Make sense?
Old Feb 1, 2008 | 04:29 PM
  #25
Mayfair's Avatar
Mayfair
So what you are saying is that if I NEED to level my truck because of tire issues but want to retain the factory raked look I should block the rear leafs. If i don't NEED the lift, I shoudn't bother.
Is that what you are saying?
Old Feb 1, 2008 | 05:05 PM
  #26
rootercycles's Avatar
rootercycles
I used the CAGE 2" leveling kit. I like it because it was made from a solid chunk of billet aluminum. Pain in the rear to install, but makes the truck sit better.
Old Feb 1, 2008 | 05:25 PM
  #27
aka_chewy's Avatar
aka_chewy
Yep...that's what I'm saying.Glade we got that straightened out
Old Feb 1, 2008 | 05:34 PM
  #28
Scott91370's Avatar
Scott91370
My 2500 doesn't sag at all when I carry the 3400# pontoon.If yours does sag when pulling I'd say get the 1.5". That way it'll run pretty level when you're pulling. If it doesn't I say get the 2".
I didn't vote because I have the differing thoughts.
Old Feb 1, 2008 | 05:50 PM
  #29
gales73's Avatar
gales73
say goodbye to any comfort in your ride....with a leveling kit it will feel like hitting 40 year old railroad tracks when u run over a bump in the road
Old Feb 1, 2008 | 05:52 PM
  #30
Mayfair's Avatar
Mayfair
Do you have a levelong kit Gale? If so, what size?
