Gauge fittings info required
Old Feb 22, 2008 | 12:33 AM
lesimon's Avatar
lesimon
Default Gauge fittings info required
Can anyone tell me the boost gauge bolt size/specifications, (metric/standard).
Fuel Banjo bolt size/specifications.
Transmission cooler line Tee size/specification, I micrometered the tubing 1/2 '.
If anyone has any part numbers or suppliers I would appreciate any information.
Last question I have to install my EGT gauge above the rear-view mirror, can I lengthen the Pyrometer probe. Autometers install instructions say that you can not. Diesel Manor say that you can. I have a digital EGT gauge. thanks for any help that you can offer.
Old Feb 22, 2008 | 12:45 AM
jakebrake's Avatar
jakebrake
Default RE: Gauge fittings info required
You can lengthen the wires.Their claim is that it will not be accurate, however the probes they use are only accurate + or - 50F. Another 8ft of wire ain't gonna effect it.
Old Feb 22, 2008 | 10:45 AM
DieselDemon's Avatar
DieselDemon
ORIGINAL: jakebrake
Make that 8 ft of wire at least 3 gauge sizes bigger than the original wire. Add the new wire as close to the sensor/probe as possible.I would think there would be no additional loss that would amount to anything.
I had to length all the wires on my Autometer Cobalts. They work fine.
Good luck with your ride.
Old Feb 22, 2008 | 10:59 AM
Drew's Avatar
Drew
one thing you have to watch is useing dis-similar metals. the connections are either going to be straight aluminum, or aluminum/cupric connectors. if you use a different metal to lengthen the line there will be a slight voltage increase that will skew the true readings slightly. granted the milivolt value change is not alot, but it is enough to give a rise in temps about 10-20F depending on the temprature of the connection.
asside from thst, yes you can lengthen the line.
you can pick up the bolt needed to get your boost numbers from geno's garage, infact just about everything you need is right here http://www.genosgarage.com/products.asp?dept=63
