Pyrometer Install?
Old Feb 25, 2008 | 01:35 AM
R8DRROB's Avatar
R8DRROB
Default Pyrometer Install?
I had a question for some of you CTD guru's. I followed some instructions that I found in the Cummings Forum on how to install an EGT Gauge. It told me to use a 7/16" bit and a 1/4"NPT tap. Well come to find out the fitting that came with my Auto Meter EGT gauge is 1/8".So my question is thiswhere canI get an 1/8" x 1/4"fitting.Im not sure if brass would hold up under those type of temps. Any help here would be appreciated. Thanks
Old Feb 25, 2008 | 02:26 AM
jakebrake's Avatar
jakebrake
Default RE: Pyrometer Install?
best bet would be a hydralic shop in your area. Course you can always try the local hardware store too. Ace hardware usually has a good selection of fittings.
Old Feb 25, 2008 | 09:22 AM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
Yeah Ace Harware should have a steel 1/4" to 1/8" reducer.
Old Feb 25, 2008 | 09:32 AM
92oilburner's Avatar
92oilburner
That should be common size reducer fitting, but DO NOT use brass!
Old Feb 25, 2008 | 10:15 AM
Drew's Avatar
Drew
ORIGINAL: 92oilburner
sounds like that comes from personal experience
Old Feb 25, 2008 | 11:27 AM
92oilburner
Not really, just the knowledge that brass has to low of a melting point to be used in exhaust systems.
Old Feb 25, 2008 | 02:46 PM
R8DRROB's Avatar
R8DRROB
Actually I found out from a guy that took a metals class that yellow brass has a melting point of constant 1706 degrees, & red brass has a constant of 1832 degrees.
Old Feb 25, 2008 | 10:07 PM
R8DRROB's Avatar
R8DRROB
I got er done today. Ifound a S/S adapter at Ace Hardware. Thanks for all your help everyone. I guess Auto Meter uses a 1/8" fitting where some other brands use a 1/4". I need to check the fitting next time to make sure. I just assumed that they all used the same size. I installed it between #3 & #4. It reads about 200-300 degrees at idle and 600-700 degrees at cruising speed. My boost peaks at 35lbs. So everything appears to be good. Thanks again guys.
