Need Advice!!
Old Mar 11, 2008 | 10:15 PM
htgriffith's Avatar
htgriffith
Default Need Advice!!
Well as some of you already knoe, I have the Mag-Hytec 727DD Tranmission pan and differentals covers coming. I need advice on the best way to maximize getting as much of the old fluid out of the transmission. I had gone as far as thinking about taking the cooling lines off and blowing through them with a small amount of air PSI to flush them. Also would it hurt to blow into the hole were the filter goes to blow throught the pump? Any ideas or good ways to do this?
Old Mar 11, 2008 | 10:26 PM
woligator's Avatar
woligator
Default RE: Need Advice!!
i have abosolutely no idea about that buddy but since oil is pressurized in thoses line at high psi i cant imagine how 100psi of air can do something bad....
Old Mar 11, 2008 | 10:36 PM
05cumminscrx's Avatar
05cumminscrx
need a flushing machine
Old Mar 11, 2008 | 10:38 PM
JimmyDiablo's Avatar
JimmyDiablo
You can take off the exit line from the cooler. and run the truck in neutral, keep adding as much fluid as you are losing until it comes out clean. then you have fresh fluid.
Old Mar 11, 2008 | 10:46 PM
htgriffith's Avatar
htgriffith
Which is the exit line? top or bottom? And if I understand you correctly, Replace the pan, Fill it up, Take the exit / discharge line off, Crank the truck and put it in "N" so the pump will pump, Let it pump a few qrt's, kill the engine, replace the fluid that I pumped out with new, and repeat till clean..
It that it?
Old Mar 11, 2008 | 10:59 PM
woligator's Avatar
woligator
make sense
Old Mar 12, 2008 | 03:49 AM
htgriffith's Avatar
htgriffith
Got a idea, Tell me what you think, Take the old filter and cut it away from the neck, Take the neck and install a hose on it, take the hose and put it into a jug with new fluid, Take the cooling discharge off and hook a hose from it to a pan/jug to catch the dirty fluid, The thinking behind this and please correct me if I am wrong, The fluid is pumped from the filter so use the hose from the filter neck after cutting it off, Use the discharge cooling line because that is were the fluid returns back to the pan after circulating through everything. Is this a good / bad idea? Or could this be a home made flush idea?
