cel light on
Old Mar 14, 2008 | 08:56 PM
olddodge's Avatar
olddodge
Default cel light on
My 06 cel light came on yesterday did the 3 clicks w/the key and got 2 codes:P0111and P2506 I found the 1st one but not the 2nd one,does anyone know what it is? Thanks, Bill
Old Mar 14, 2008 | 09:12 PM
Drew's Avatar
Drew
Default RE: cel light on
you sure it wasnt "P2509' ECM/PCM Power Input Signal Intermittent"
how is your truck running???
Old Mar 14, 2008 | 09:18 PM
Parts/Service's Avatar
Parts/Service
I don't see p2506 in the diag section....
Old Mar 14, 2008 | 11:32 PM
73Jim's Avatar
73Jim
Rut Ro, I just had a P2509, but mine was due to a broken battery cable. Check your batteryconnections.
Old Mar 14, 2008 | 11:44 PM
12valveman's Avatar
12valveman
hey jim which cable was broken and where was the break located at?
Old Mar 15, 2008 | 12:33 AM
73Jim's Avatar
73Jim
It was the passangers side battery + cable. The clamp (lead)was torn and could not tighten any further.
[IMG]local://upfiles/54996/1C98A028D281418AA2B388A4245026D2.jpg[/IMG]
Old Mar 15, 2008 | 12:34 AM
73Jim's Avatar
73Jim
Oops, it was the drivers side.
Old Mar 15, 2008 | 10:52 AM
12valveman's Avatar
12valveman
hey jim thanks for the info will probably use that info in the future thanks again
Old Mar 15, 2008 | 09:41 PM
olddodge's Avatar
olddodge
My fault it was a P2509 truck ran fine it has a load of wood in it right now.I am taking it to the dealer on Tues. to get them corrected.I appreciate the responces. Bill
Old Mar 15, 2008 | 10:16 PM
Parts/Service
I think that Jim called this one. The follow are possible causes of this code....
Possible Causes
POOR CONNECTIONS AT THE BATTERIES
LOW BATTERY VOLTAGE
OPEN FUSED B+ TO ECM
OPEN GROUND CIRCUIT
BATTERY + SHORTED TO OTHER CIRCUITS
RETURN CIRCUIT SHORTED
BATTERY + SHORTED TO GROUND
