got a question about my idle
Old Mar 16, 2008 | 09:01 PM
soniclm's Avatar
soniclm
Default got a question about my idle
Well this morning my truck had a hard time starting because it cranked over awhile then it started. After reading this forum I guessed it was bad fuel since I filled up at a place cause the diesel was like 20 cents cheaper so I added some PSD to it and it seems to start better but I just noticed this evening, the truck in park it idles kinda rough but it gear it idles good. Does anyone have an idea what the problem could be?
Old Mar 16, 2008 | 09:13 PM
Drew's Avatar
Drew
Default RE: got a question about my idle
I would check your lift pump and make sure it is pushing enough fuel.
Old Mar 16, 2008 | 09:18 PM
soniclm's Avatar
soniclm
well my lift pump is maybe 4 months old, it only runs for a second but if I bump it, it will run its normal time, the lift pump running issues started after I ran my friends Smarty for a night.
Old Mar 16, 2008 | 11:31 PM
woligator's Avatar
woligator
soniclm:same as me,when i turn key on pressure goes about 5psi than goes down,when i bump engine fuel pressure came one...
Old Mar 18, 2008 | 05:20 PM
soniclm's Avatar
soniclm
I hooked a fuel pressure gauge up to my truck and I turn the key and I don't think it registered anything but when I bump it, it goes to 18 and idling is stays at 15.
