How do I check my ujoints???
Old Apr 5, 2008 | 03:35 AM
Erock509's Avatar
Erock509
Default How do I check my ujoints???
Last time I took the truck in for warranty work, the tech stated that the ujoints would need to be replaced in the near future. How can I check them myself to se if they need to be replaced?
Old Apr 5, 2008 | 06:27 AM
sabersix's Avatar
sabersix
Default RE: How do I check my ujoints???
Drive slowly in a circle, first one way then the other. Listen for a clicking sound from the front end and/or some kick back through the steering wheel.
Old Apr 5, 2008 | 07:55 AM
olddodge's Avatar
olddodge
You can go under the truck grab the drive shaft at the u-joint and shake it.There should be no movement in the shaft.You can also put a pry bar on the joint and try to move it that way.
Old Apr 6, 2008 | 12:53 AM
Erock509's Avatar
Erock509
Ok thnx ill try those suggestions. I also noticed when i reverse out of my driveway and cut the wheel to the right, just before i put it in drive and the truck comes to a stop in R, it makes a solid thud sound. Not sure where thats coming from, always thought it was the lift or axel, any ideas??
Old Apr 6, 2008 | 01:01 AM
RamItOne's Avatar
RamItOne
ORIGINAL: sabersix
now how are you gonna hear clicking with yall sparkplugless *** engine clanking? lol, careful, clicking could be your teeth eating itself
grabbing the u joing is the best...
