Speaker making whistling noise!!
Old Apr 5, 2008 | 09:33 PM
SC Willie's Avatar
SC Willie
Default Speaker making whistling noise!!
I had my speaker upgraded in my 06 Ram QC and they are making a high pitch whistling noise.
Any advice?
Old Apr 5, 2008 | 09:59 PM
Drew's Avatar
Drew
Default RE: Speaker making whistling noise!!
do they do it all the time???
Old Apr 5, 2008 | 10:03 PM
dirtydodge02's Avatar
dirtydodge02
Or does it only do it when your RPMs are up? There's also a possibility that the Positive and Negative wires are hooked up backwards.
Old Apr 5, 2008 | 10:07 PM
SC Willie's Avatar
SC Willie
All the time even when the mute is on. I think that the hook ups on the speaker may be to close to metal and maybe making contact.
Old Apr 5, 2008 | 10:38 PM
dirtydodge02
Good possibility. Also, you might check on theaudio/visual forum here: https://dodgeforum.com/forumid_17/tt.htm. The guys in there may have a better understanding of exactly what's going on.
Old Apr 6, 2008 | 12:40 AM
Ben D.'s Avatar
Ben D.
sounds like alternator whine to me. was it installed by u or professionally. if it was done by a shop take it back. because they have a massive amount of **** somewhere in that install.
Old Apr 7, 2008 | 01:20 AM
beachmstr's Avatar
beachmstr
is the system amp'd? Check the amp to make sure the speaker wires and the power wire aren't crossing. also check and see if they ran RCAs and power wires on the same side. this will give a similar reaction to what ur getting, commonly referred to as "road noise"
