DIY Questions
Old Apr 7, 2008 | 09:53 AM
Scott91370's Avatar
Scott91370
Default DIY Questions
Friday I decided to pull the wheels off the truck to check the brakes because the truck was pulling left really bad.So bad than if I had to press down with more than about 50% force it would almost change lanes.Turns the hub assembly in the drivers side was bad. When I would move the rotor there was about 1/4" of play (total of 1/2" top to bottom difference). I've got a 2001 so I get NAPA to order me one ($219, not bad considering the next cheapest I could find was $300 at the dealer). Pick it up Saturday and it's wrong. Right part for the 2001 but apparently mine has an axle (spindles) from a 99 and older. Get the correct one put it all together and spend 2 hours trying to find a 1-11/16" socket to tighten the hub axle nut.
Now the questions-
1) What is the correct torque for the axle nut (on a 1999, 2500 4x4)?
I have found 135#, 170# and 180#. This seems very high (not to mention a wide range)to me, but they are different than regular wheel bearings, so I don't know.
2) Is bleeding the rear wheel abs model the same as beeding a regular breake system, or do I need to do somehting different? (manual makes it sould like it's a normal bleed job)
Replacing the hub and brake pads took away about 99% of the pull. The pull only happens now if I am not holding on to the wheel. I'm sure an alignment and rotating the tires would take care of this.
Old Apr 7, 2008 | 10:09 AM
dirtydodge02's Avatar
dirtydodge02
Default RE: DIY Questions
I'd think that 135 is the correct number, but I'm not 100%. However, yes, ABS bleed the same as non-ABS applications.
Old Apr 7, 2008 | 10:14 AM
dirtydodge02
Ok... I was wrong. Check this out http://www2.vsm.skf.com/Files/Brochu...PDF/457377.pdf Looks like you should be at 175#, not 135
Old Apr 7, 2008 | 10:24 AM
Scott91370's Avatar
Scott91370
That's a great page! Thanks.
