Oil\Filter\Fuel filter all changed
Old Apr 10, 2008 | 05:21 PM
mikebol's Avatar
mikebol
Default RE: Oil\Filter\Fuel filter all changed
That's good to know, Drew. I hadn't thought about how the placement high on the block would have affected it.
Mike
Old Apr 13, 2008 | 07:59 AM
Joel_MD's Avatar
Joel_MD
Mike, was that the factory oil filter you removed? Mine was unbelievably tight when I didthe first oil change. Someone said they actually use some sort of varnish at the factory to seal the filter to the block.
I don't suppose you had a used oil analysis performed, did you? A few of us 6.7L guys are getting our oil anaylzed by Blackstone or Oil Analyzers (Amsoil) after we change it. My engine seems to have a problem with fuel contaminating the oil. See this post. I am going to change it again in the next few days after only 5,000 miles to see if the fuel contamination problem still exists.
It's good to know you can change the fuel filter in 25 minutes. That's not too bad considering you have to remove the wheel well liner.
Old Apr 13, 2008 | 08:51 AM
mikebol's Avatar
mikebol
Thanks Joel for letting me know and all the good information in your other post. I'll definately be sending off a sample once I get 5k miles on this batch of oil. Hopefully it comes out Ok.
Mike
