Check Gauge Light
Old Apr 11, 2008 | 09:12 PM
amock's Avatar
amock
Default Check Gauge Light
Need some help guys, every once in awhile ill be drivin around and the gauges read fine and all is good. Then for some reason the check gauge light will come on for maybe a second then shut right back off. Should I worry about this or ignore it. Thanks
Old Apr 12, 2008 | 01:40 PM
Mayfair's Avatar
Mayfair
Default RE: Check Gauge Light
I too had that problem. It would happen as a result of my cam position sensor going out, so my tach would sink for a few seconds.
The best thing i can tell you is to either get yourself something that you can check codes with, or go to Autozone and they will hook up a scanner and check it for free.
Bottom line .. if the light is on, it's trying to tell you SOMETHING. Ignoring will will only eventually bring on the enevitable.
Old Apr 13, 2008 | 07:40 PM
CowboyBob's Avatar
CowboyBob
That light comes on when one of your gauges drops or rises suddenly. It came on when my alternator caught on fire and the gauge dropped below 8v. I don't think it throws any codes in the computer, at least not on my 2nd gen.
