tranny slip
Old May 4, 2008 | 10:35 PM
blownsoot's Avatar
blownsoot
Default tranny slip
Most people seem concerned about it, but I have a couple questions.
How much is bad?
Will any ruin the tranny or can they handle a limited amount?
Which is worst band slippage or converter clutch slippage?
Old May 5, 2008 | 08:05 AM
cumminalong's Avatar
cumminalong
Default RE: tranny slip
It's gonna have some slip to it, it's the repeated effects that really take their toll.
You'll see it slip in two different areas....
1 - Under hard accelleration, you'll see more band slippage than TC. This is because the TC hasn't locked up and the bands can't clamp pastenough.
2 - You see TC slippage under hheavy loads or high power once it's locked.
One thing I try to do to prevent / mitigate it a bit is really watch how much throttle I get into in that 2nd to 3rd gear shift. That's where I see the most slippage.
Also, if you're in that 45 - 55 MPH range and it goes from 4th (TC Locked) to 3rd, you'll see quite a bit.
I try to drive mine almost all the time in T/H mode, just for the higher line pressure and firmer shifts.
I rarely see my tranny temp over 180 and the ONLY time I've had it hit 200 was towing a couple 8K+ trailers up into North Alabama.
But, I'm also tired of babying it, so it's gonna be making a trip to Sun Coast here real soon. It's only a 4 hr ride for me.
Old May 5, 2008 | 10:30 PM
blownsoot's Avatar
blownsoot
I did a 1/4 mile performance test on the banks yesterday and in the last 2 seconds my speed stayed at 87 but my exhaust temp kept climbing and rpms kept climbing. After the test when I would get on it on the freeway with the converter locked the rpms would climb200 to 300then slowly come down as the trucks speed went up. The last thing I want to do is smoke my tranny at this point.
Old May 6, 2008 | 01:05 AM
Ben D.'s Avatar
Ben D.
yea definately getting some slippage there buddy. a bit more than what would be normal. I would maybe turn down the banks tuner a bit. this is a frequent discussion but you gotta pay to play. and if you are worreid about paying for a new tranny then I would just set her back to a lower level or stock. because other than that no one can garantee you will be Ok.
Old May 6, 2008 | 01:27 AM
blownsoot's Avatar
blownsoot
I usually run in level 3 but had a wild hair and decided to see what 5 would do, after the tranny cooled down it hasn't had anymore slippage.
