Decal opinion
Old May 20, 2008 | 10:42 PM
  #31
CowboyBob's Avatar
CowboyBob
Default RE: Decal opinion
I paid $28 for mine. I have not installed them yet. Does anyone know the best way to install them and not get air bubbles in it?
Old May 20, 2008 | 11:02 PM
  #32
firemedic740's Avatar
firemedic740
Ive decalled alot of trucks at work and this is my theory:
1. Make your measurments with something cleanable
2. Run a piece of 2" tape along one whole side of the decal
3. Align the decal with your measurements
4. Recheck the measurement for accuracy
5. Spray the surface with water and a little bit of dishsoap mix
6. Peel the back of the decal
7. Spray the back of the decal with the solution
8. Try to roll the decal on evenly
9. Squeege the water out starting from the center.
10. Let the decal set before peeling the outside sheet off
Its worked for me with no problems, Im taking that these decals are made the same way. If you don't let the decal set it will come off when peeling the final sheet off.
Old May 20, 2008 | 11:56 PM
  #33
reed's Avatar
reed
How long should you let it set?
ORIGINAL: firemedic740
Old May 21, 2008 | 01:21 PM
  #34
Mayfair's Avatar
Mayfair
ORIGINAL: CowboyBob
I was wondering if you'd gotten the stripe yet. It's gonna look AWESOME with your painted hood !!
Old May 21, 2008 | 07:06 PM
  #35
firemedic740
I let it set for at least 10 minutes
Old May 22, 2008 | 07:44 PM
  #36
8 lug's Avatar
8 lug
I would go w/ a metallic silver. It would compliment your grill, step bars, & wheels
Old May 22, 2008 | 10:17 PM
  #37
handymanherb's Avatar
handymanherb
I did my race car every year, just keep it wet with a little soap and you can move them anywhere you want and went you like it, squeegee the water out from under them and let dry.
Old May 23, 2008 | 01:03 AM
  #38
klings designs's Avatar
klings designs
Here you can find some good info on installing the bedstripe.
https://dodgeforum.com/m_870447/tm.htm
