My engine fuse keeps blowing!!! help
Old May 20, 2008 | 07:03 PM
cumminskid92's Avatar
cumminskid92
Default My engine fuse keeps blowing!!! help
just today my truck was idling in my driveway for about 15 minutes and then it just shut off. i checked all the fuses and the "engine fuse" inside the truck was blown. it is only a 10amp fuse so i replaced it but it kept blowing. im not really sure what this fuse controls. does anyone know why it might be blowing or if there could be a short? i didnt want to but i tried puting a 20amp fuse in and it blew that to. anything would help
Old May 20, 2008 | 07:39 PM
Drew's Avatar
Drew
Default RE: My engine fuse keeps blowing!!! help
I would trace that line and see where it leads. my guess would be the shutoff solenoid if you are refering to a 12 valve.
it may need replacing.
Old May 20, 2008 | 07:45 PM
cumminskid92
do u think there might be anything else that fuse might control....that shutoff solenoid i think your talking about was messed with by the preivious owner i think. all it does now is control the power to my dump bed..its pretty weird and i want to rewire it.
Old May 20, 2008 | 07:56 PM
Drew's Avatar
Drew
that solenoid is the only thing other than running out of fuel that will cause that engine to shut off
Old May 20, 2008 | 08:00 PM
cumminskid92
would a bad solenoid cause the engine fuse to keep blowing?
Old May 20, 2008 | 08:21 PM
jakebrake's Avatar
jakebrake
it could cause it. Three wires to that soleniod. two are power and one is ground. Put a meter to it and see what it reads across each coil and from each coil to the soleniod body.
