2004 Ram Diesel Electrical Problems....... NEED HELP
Old May 23, 2008 | 08:19 PM
jackbobtom's Avatar
jackbobtom
Default 2004 Ram Diesel Electrical Problems....... NEED HELP
Hi All,
I am new to this forum, but hopefully someone can help.
We have a 2004 Dodge Ram 3500 with the 24v Cummins engine fitted and it has allsorts of gremlins with the electronics. The truck has been stood for 12 months (elsewhere) or so and was believed to be running (although not very well) beforehand. The batteries had gone flat in this time.
We have charged the batteries off the vehicle and refitted them. (both seem to be holding charge fine)
Things that DO NOT work:-
1. keyless entry
2. Fuel gauge and volt meter does not move with ignition on.
3. Diagnostic (on-off 3 times does nothing) Plugging in a scanner does nothing either(says no communication)
4. Several warning lights come on with ignition, go out and come back on one at a time with a chime for each one.
5 Fuel pump is not constant, it pulses. (have tried testing the feed and the feed is pulsing) The injectors can be heard pulsing also with ignition on but not turning over. (clicking noise )
The engine will spin over but will not start. (Not tested for fuel at fuel rail yet)
The vehicle Vin has been checked at a Dodge dealer in the US and it has been confirmed that it does NOT have the "Sentry" key system fitted.
Overhead is working but when fuel distance selected there is just a line --
We have put 5 gallon of fuel in and no change.
All the fuses and many of the connections and grounds have been checked.
[/align]Any ideas anyone?
Any suggestions would be gratefully received. ( before I start stripping it down)
We are in the United Kingdom so taking it to the Dealer isn't really an option.
[/align][/align]
Thanks for listening, please let me know your thoughts.
Cheers, John
Old May 24, 2008 | 02:06 AM
gtxpooch's Avatar
gtxpooch
Default RE: 2004 Ram Diesel Electrical Problems....... NEED HELP
How did it get over there? Did it come from any of the southern united states that got hit by hurricanes? BTW, welcome to the forum. Sorry I can't help much more.
