12v turbine housing
Old Jun 8, 2008 | 11:43 PM
finny's Avatar
finny
Default 12v turbine housing
well i am gathering the parts i am going to need to make more hp.i am looking at a #10 fual plate and 75-100hp injectors. that should be making around 350-400 hp so my question is what size turbine housing should i put on the stock hx35? 12cm-14cm-16cm?i will also be adding a 60mm compresssor housing with a 6 blade impeler.
