TURBO PROBLEMS!?
Old Jun 20, 2008 | 08:17 PM
olegoofynut's Avatar
olegoofynut
Default TURBO PROBLEMS!?
I need some input. My truck recently started acting FUNNY!! Iget a dead pedal you know little to no boost. Also, I get a little white smoke every now and then. Is my injection pump going bad?????????? THANKS for your advice!!
Old Jun 20, 2008 | 09:36 PM
NickBeek's Avatar
NickBeek
Default RE: TURBO PROBLEMS!?
You'll get more and better responses if you list year, trans, mods, etc about your truck. Fill out your signature (like at the bottom of my post) .
Old Jun 20, 2008 | 10:16 PM
lilfroger's Avatar
lilfroger
since his user name has Goofy in it I'll help him a bit .....from his profile he has a "2002 Ram 2500 cummins diesel"
You're going to want to check for any codes. (turn the key 3 time to the on position but do not start it - codes will come up on the ODO)
You might also want to check these threads:
https://dodgeforum.com/m_529409/tm.htm
https://dodgeforum.com/m_1056746/tm.htm
https://dodgeforum.com/m_1320465/tm.htm
