hey guys i own a 98 doge dielse cummings engine, how do i make it smoke more
just wanna smoke out all those little ricers you know
cummins
100 horse injectors would do the trick just fine. May want to upgrade your lift pump to a fass if you still have the stocker. Just remember when you add fuel you want to add air or your egt's eill get out of control quick. Don't do anything until you have a good set of gauges.
For smoke it is all about fuel. Black smoke is unburnt fuel. So you have to put more into the system than it can burn.
Larger injectors
Higher fuel pressure
adjust timing
A programmer can do 2 out of the 3 really quick and produce amazing results.
Larger injectors
adjust timing
if the truck is a 98.5 with the 24 valve 5.9 then the adrenaline module by quadzilla not only will give you as much smoke as you want but also give you tons of power. before doing too many upgrades i would make sure that you upgrade you lift pump set up to either a fass system or an airdog. this will help keep enough fuel pressure to feed the vp44 when it is calling for mass amounts of fuel that is assuming you have a 98.5.
Holy crap dude.....with $6/gallon diesel in canada I wish I could afford to turn up the smoke!!!
