Need Help ASAP!
I just bought a new quadzilla adrenaline and installed it to the T as the instructions stated. Now my truck won't start! Everything has been checked and double checked. Its all correct. I've even unplugged everything and tried to go stock and my truck won't start. I just got my truck back from the shop for a new lift pump and injector pump so i really hope its not that but please if anyone can help.
If its cranking and not starting its and leak somewhere in the fuel line
i bet on #6 injector nut loose, its very hard to reach and easy forget to retight it....
check all connections on the injection pump and on the head first to find the one who can be loose,if nothing to be found
slack #1-3-4 injector line at the head and crank engine till it start,then shut them close but dont strip the treads....
dont bother whit #2 cuz its hard to reach
after that check every connections whit engine running to found faulty one
I have broke injectors 1,3&5 lines open and i get fuel out of line 5 but not out of the others. It just doesn't make sense i just got the truck back from the shop with a new lift and injector pump. it was running great until i plugged the chip up and now all it will do is crank and crank but not even a sputter. Its hard to believe that the chip whipped out my injector or fuel pump this soon since it never ran but i don't know any help will be great.
I doubt the chip had anything to do with your current problem, as woli said sounds like air in the lines. your new lift pump may have an issue, do you hear it running when you turn the key?
u didnt wiped anything,if it got air in the line it wont even try to start,what u are describing really sound a air leak...maybe u can crack the fiting that go into the injector pump,the leak can be at the lift pump too...have a buddy crank the engine and let some fuel goes out by this place then tigh it back
then after that go on the injector that ton spill fuel...if they arent spilling fuel loosen them a bit more,it will spill fuel,it cant be other way...
