dual ac problem
Old Aug 5, 2008 | 10:17 AM
bradbates1998's Avatar
bradbates1998
Default dual ac problem
i have a 2003 dodge ram 2500 cummins diesel quad cab laramie 4x4 and my ac is giving me some problems and i wonder if anyone out there know what might be going on... the driver side gets colder than normal and blows out a steam like cloud and the passanger side just blows air no cold ac but if you put it on heat it works fine on both sides..... i talked to dodge and they think its a actuator behond the dash and will take 8 hours to fix at 60.00 a hour (ouch 480.00 just in labor) they said the complete dash has got to be removed to access it can someone help me on this mannor
Old Aug 5, 2008 | 11:04 AM
Bass Hunter's Avatar
Bass Hunter
Sounds like the blend door or blend door actuator is broken. This is a fairly common problem on these trucks and yes the entire dash has to be removed which is very labor intensive. Member Parts/service works at dodge and may be able to tell you more.
