Pro Comp Xtreme AT's
Old Aug 12, 2008 | 08:49 AM
steve05ram360's Avatar
steve05ram360
From a safety standpoint last winter when they were around 65k miles I did a wet pavement brake stomp to see how well they gripped and to my suprise, they stopped pretty well. Better than any bfg at I'd had. I dont think they would do well in snow right now but hey, I live in CA... what is snow?
they get rotated front to rear only since they are directional. and about every 5~7k miles. sometimes more often depending on wear. I had a front end issue that was causing some cupping on the insides so the rotation was a little more frequently back then.
Old Aug 12, 2008 | 12:31 PM
mmstar23's Avatar
mmstar23
alright. just wondering if the front to rear only is ok since theyre directional. im gonna rotate mine about every 3k miles. if you drive a lot, i wouldnt do it that often, but 3k miles is a couple months for me and i can live with rotating once every few months. thanks for the input steve
Old Aug 12, 2008 | 01:21 PM
Mayfair's Avatar
Mayfair
I rotate mine at every oil change ( every 5K )
Old Oct 23, 2008 | 09:17 PM
Aruba1's Avatar
Aruba1
I need a set of new tires soon and these seems to be the best. What is the load rating? E?
Old Oct 23, 2008 | 11:01 PM
gtxpooch's Avatar
gtxpooch
Are they noisy on the highway?
Old Oct 23, 2008 | 11:25 PM
steve05ram360
load rating E is the toughest of the passenger truck tires, not sure if there are higher ratings for bigger trucks or not but E is what you'd want if your towing. To date I have over 82k on mine, still have tread left and still seem to be doing fine. Have had no balance issues with them, they are pretty tough, I had a 3/8" or so drill bit removed from one of them and was expecting problems with that tire but never had any. IIRC, I've had 2 flats repaired over the 82k miles.
I highly recommend them.
Old Oct 24, 2008 | 10:44 PM
Aruba1's Avatar
Aruba1
Steve, do you have the "all terrain" or the "mud" ones?
Old Oct 25, 2008 | 07:12 AM
steve05ram360
they are the AT's
