warranty question
Old Aug 13, 2008 | 06:16 PM
294 chief's Avatar
294 chief
Junior Member
Default warranty question
can any body tell me what the powertrain warrenty is for the cummins diesel, is it 10 yrs,100,000 or is it 5 yrs,100,000? i have a 03 with 78,000 miles on it, and is up the local mechanics, he told me to contact a tranny shop because there is something TERRIBLY WRONG WITH IT. I dont have the book infront of me,and the dealers service dept. is closed. any help would be greatly appreciated.:confuse d:
Old Aug 13, 2008 | 08:24 PM
triton's Avatar
triton
your warranty is only 3yrs/36000 on the powertrain. The 100K warranty is only for the Cummins engine itself.
Old Aug 14, 2008 | 05:25 PM
cumminsowner's Avatar
cumminsowner
Junior Member
Default Warranty
Cummins 6.7 liter, ENGINE 5 Years / 100,000 miles.
Rest of the truck...including TRANSMISSION 3 Years / 36,000 miles.
Extended warranty available for extra $$$$ . Extending rest of truck to Cummins 5yr 100k is not rediculous...about 1500.00.
Extending cummins warranty with truck to 7 years 100K or 150 K....is like 4,500.00
I typically extend the warranty out for the loan period...after that, you have no more payments and can afford a repair or two...
Emissions part to 5 Years / 120, 000 Miles some parts to 3 Years 70,000 miles.
Read the fine print in the owners manual warranty booklet, there is a bar graph that shows the emissions warranty.
Old Aug 14, 2008 | 08:29 PM
Parts/Service's Avatar
Parts/Service
In 2003, the powrtrain warranty was 7year/70,000 miles. The following is out of the warranty for a 2003...
2.2 Powertrain Limited Warranty
A. What’s Covered:
The Powertrain Warranty covers the cost of all
parts and labor needed (less a $100 deductible per
repair visit at the end of the 3 Year/36,000 Mile
Basic Limited Warranty) to repair a defective
powertrain component listed in section 2.2.F
C. When It Begins
The Powertrain Warranty begins at the end of the
Basic Limited Warranty, on either of the following
dates, whichever is earlier:
• the date your truck has been in service for
more than 36 months; or
• the date you've put more than 36, 000 miles on
the odometer.
D. When It Ends
The Powertrain Warranty lasts for 7 years from the
date your truck has been in-service or 70,000 miles on
the odometer, whichever occurs first.
F. Parts Covered:
The Powertrain Warranty covers these parts and
components of your truck's powertrain:
Gasoline Engine: cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake
and exhaust manifolds; flywheel with starter ring
gear; core plugs; valve covers; oil pan; turbocharger
housing and internal parts; turbocharger wastegate
actuator; supercharger; serpentine belt tensioner;
seals and gaskets for listed components only.
Rear Wheel Drive: rear axle housing and all
internal parts; axle shafts; axle shaft bearings; drive
shaft assemblies; drive shaft center bearings;
universal joints and yokes; seals and gaskets for
Diesel Engine: cylinder block and all internal
parts; cylinder head assemblies; core plugs; fuel
injection pump and injectors; intake and exhaust
manifolds; oil pan; oil pump; timing gear drive
belts and/or chains and cover; turbocharger housing
and internal parts; valve covers; water pump and
housing; seals and gaskets for listed components
only.
Transmission: transmission case and all
internal parts; torque converter; drive/flex plate;
transmission range switch; transmission control
module; bell housing; oil pan; seals and gaskets for
NOTE: MANUAL TRANSMISSION CLUTCH
PARTS ARE NOT COVERED AT ANY TIME.
Four-Wheel Drive (4X4): transfer case and all
internal parts; transfer case control module and shift
mode motor assembly; axle housing and all internal
parts; axle shafts; axle shaft bearings; drive shafts
assemblies (front and rear); drive shaft center bearings;
universal joints and yokes; disconnect housing assembly;
seals and gaskets for the listed components only.
2.3 Cummins Diesel Engine Limited
Warranty
A. When It Begins
If your truck is equipped with a Cummins Diesel
Engine, the Cummins Diesel Engine Limited
Warranty begins at the end of the 3/36 Basic
Limited Warranty period, and covers the cost of
repairing those parts of your truck engine listed
in Section 2.3.B that are defective in materials,
workmanship, or factory preparation.
B. Parts Covered for 7 Years or 100,000 Miles
In trucks equipped with a Cummins Diesel Engine,
ONLY the following engine parts and components
are covered for 7 years or 100,000 miles, whichever
occurs first:
• cylinder block and all internal parts
• cylinder head assemblies
• core plugs
• fuel injection pump & injectors
• gaskets and seals for listed components
• intake and exhaust manifold
• oil pan
• oil pump
• timing gear drive belts and/or chains and cover
• turbocharger housing and internal parts
• valve covers
• water pump and housing
A $100 deductible per repair visit applies after
your truck has been in use for 5 years, regardless
of mileage.
http://www.dodge.com/en/owners/ <<<< click to go to a Dodge site that will let you download a warranty manual for your vehicle...
