Problem with Rough Idle only at a dead stop!
Old Sep 8, 2008 | 04:27 PM
cec311's Avatar
cec311
Default Problem with Rough Idle only at a dead stop!
04' 3500 5.9 manual. Truck fires up perfect and idles perfect. When you head down the road and come to a stop sign or light the truck will idle fine and then drop 500 rpms and then back up etc... until I give it a little gas and the idle comes back to normal and it will be fine until the next light. Any guesses what may be causing this?
I know its not the filters as I changed them all about 500 miles ago.
Old Sep 10, 2008 | 11:03 PM
montanadodge's Avatar
montanadodge
Sounds like the FCA needs replaced. $100 from Cummins and about 15 min. should do the trick.
Old Sep 12, 2008 | 01:51 PM
cec311's Avatar
cec311
I think I have one battery that may need replacing. The little light is jet black. Could the battery be pulling the idle down at stop?
Old Sep 12, 2008 | 10:34 PM
dirtydodge02's Avatar
dirtydodge02
I suppose in theory it could be a battery... could be stalling the pump out. What's you're voltmeter read when you stop?
