Need Auto tranny help!!!
Old Oct 30, 2008 | 08:09 PM
High_On_Diesel's Avatar
High_On_Diesel
Default Need Auto tranny help!!!
Ok...have an 06 2500. Installed Triple Dog on it. Stock trans. Had a bit of fun. Now the problem... At stop in drive truck refuses to go into first. Rev engine...will eventually kick into gear. Regardless of RPM's when in gear truck barely moves. Will switch into 2nd but thats it. When in 2nd same scenario...can rev thru RPM range with little acceleration. Trans slips bad and will not shift past 2nd. Understand new trans is prolly needed. Anyone have this prob before? If so...after new trans is installed or parts, what can I do for a reasonable price to upgrade components? Thanks for the help guys!!
Old Oct 30, 2008 | 11:19 PM
SpLaT's Avatar
SpLaT
Purchase a built tranny.... pay to play.
Or replace tranny with OEM and install upgraded valve body and torque converter will help some.
Old Oct 31, 2008 | 12:08 AM
High_On_Diesel
Talking
Ya...I figured as much....That was the plan but jus taking more experienced suggestions. Thanks for the info!
Old Oct 31, 2008 | 10:06 AM
SpLaT's Avatar
SpLaT
its quite plain... you've burned out the tranny!! needs a rebuild or OEM or aftermarket tranny. if you decide to rebuild, go with a good aftermarket torque converter, valve body and if your planning to continue doing burnouts and boosted launches... billet input and output shafts....
Old Nov 1, 2008 | 04:09 PM
High_On_Diesel
Thanks for the info guys
