Boost gauge and pyro probe
Hey guys quick question where can you get a boost gauge and pyro probe for a 92 cummins and also the gauges that mount on the a pillar, my buddy is lookin for them and any help would be greatly appreciated. Also where can you get a Denny T Pin from thanks
these guys should be able to hook you up...
http://www.tstproducts.com/
or http://www.atsdiesel.com/ats_new/
www.genosgarage.com
www.dieselmanor.com
Those are both good sources for parts. Dont buy anything from ATS, theyre a bunch of scumbags as far as Im concerned...
To get "THE" DennyT pin, you have to get hold of him. The only way I know of is to login to DTR and pm him. Or you can grind your own pin...
Heres a link to pretty much all the info for a first gen you could need:
http://www.dieseltruckresource.com/d...d.php?t=102027
Towards the bottom theres a section on performance. Explains how to adjust the fuel screw, grind the pin, AFC adjustments, governer spring, etc.
www.dieselmanor.com
http://www.bullydog.com/product/inde...uct_detail/172
Im trying to find others. I lost all my links when my old comp. crashed...
Ok, found some more:
http://www.dynomitediesel.com/display_part/18.php
http://www.xtremediesel.com/bullydog...lpin42190.aspx
http://www.pdrdiesel.com/products/Cu...n-932-146.html
