failed lift pump, won't start now?
I replaced the injector pump and it started right up, it seems by most accounts if the lift pump goes out you will end up replacing the injector pump. I will install a fuel pressure guage. I haven't decided if I will install a mechanical or go with electric.
mechanical is cheaper and far more reliable/accurate.
get yourself an isspro 0-30psi mechanical with a tapped banjo bolt, a needle valve, and 6' of 1/8" airbrake line from napa.
put it all together and you have an extremely accurate and reliable gauge for about $65.
Thanks Jigabob. I will go with the mechanical guage. I would like to use some kind of flexible fuel hose if I can find it. I was a mechanic for many years and when you go from the engine to frame you really need some flex.
are you talking about for the gauge? if so: you can always put in a grease gun hose if you want a flexible section from the fuel filter housing to the gauge line....otherwise airbrake line is pretty flexible and very strong.
